Old plan on 5g
ramzes
Hi, Im thinking of changing to the promotion plan of $39 per month 20gb at 4g speed. My current plan is the old $45 per month but it says 5g on the top. Will it change the speed?
7 REPLIES 7
I think both 4G and 5G will be throttled exactly the same.
gpixel
it's the same concept as with the 3g plans. IT is now safe to leave 5g enabled. I have a suspicious feeling that only the 5g will be throttled. I will do some tests in the near future when the roll out is more official and see if it is true
*update
5g normally uses more CPU usage and heats up the device especially with a weak signal so I've switched back to lte. unless I'm experiencing weaker data bandwidth on LTE I'm not going to use 5g. better battery efficiency is the better option
All the plans should have access to 5G now, but "4G speed" plans will be throttled to 100 Mbps.
kb_mv
@bjs23 wrote:
Just switched to the $39 plan. Says 5G at the top but of course limited to 100mbps speeds
@bjs23 See my reply above vis a vis forcing your phone onto LTE only....
HI @ramzes
both $45 and $39 are LTE/4G plans. Same speed
bjs23
kb_mv
@ramzes The $39 plan is at 4G/LTE, same as the $45 plan regardless of what your phone hooks up to. Switch your phone to only select 4G/LTE and you will notice a marked improvement in your speeds. Hooking up to 5G actually hinders it (unless of course you subscribe to a 5G plan).
