Item not found error
duane7s92
Hi,
I'm getting email notifications that I have received a message from Public Mobile. However, when I follow the link, I get the below error. I also see no messages in my inbox.
I was able to see messages prior to setting up a username.
Any ideas how I may be able to view these messages? Thanks.
@duane7s92
I think you need to open ticket with PM Support then:
             Click "Yes, I'm a customer", then click "Sign In", once signed in, ignore the choices and type "Contact agent"
              Then click "Contact Us", and click "My Account".  Finally click "Click here to submit a ticket ↗ " and you can open the ticket
2. Or if you have trouble with Chatbot, Private message CS agent at
duane7s92
Same thing in incognito
@duane7s92   try to login using a different browser or using Incognito mode and see if it works
