06-26-2022 03:25 PM
I no longer have access to the email address I used to sign up for Public Mobile, but I need the password reset function. How can I change my password without access to this old email address?
I tried to submit a ticket, but that requires you to log in (which I can't do without resetting my password). I also tried chatting with a moderator directly, but I was only redirected to the website where you submit a ticket.
My Account
06-26-2022 03:34 PM
@cloe_allard please follow this to reset password
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
06-26-2022 03:29 PM - edited 06-26-2022 04:28 PM
@cloe_allard Hi if you can’t get into your account you can to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
06-26-2022 03:29 PM
@cloe_allard If you don't remember your password then you need to submit a ticket via chatbot for a reset and can also request that your email be updated to a new one at the same time. Here's a link to chatbot: https://www.publicmobile.ca/en/on/get-help
