11-01-2022
07:34 PM
11-01-2022
08:21 PM
computergeek541
11-01-2022 11:13 PM
I don't think that belongs in the blue box!
11-01-2022 07:54 PM
If that SIM was once active and then service was cancelled = No. You can recycle it (blue box).
If SIM was NEVER activated = Yes. Activate it and use it until you cancel service and then see above.
11-01-2022 07:45 PM
You pay for the sim up front...then activate with a plan. If that plan is later suspended for longer than 90 days...the sim is now effectively trash...not usable again.
If the sim was never used...you should be good to start an account.
When was that sim last used ?
11-01-2022 07:41 PM
Public Mobile is fully prepaid, so yes. AFAIK they don't offer postpaid.
11-01-2022 07:39 PM
Even if it's only prepaid?
11-01-2022 07:38 PM
11-01-2022 07:36 PM
No not if it's been used before and deactivated.
11-01-2022 07:36 PM - edited 11-01-2022 07:36 PM
Was the sim already used on PM before and the account was closed due to nonpayment? If yes…you cannot use it again.
11-01-2022 07:35 PM
A sim that's just old but never activated should be fine. If it's already been used ...forget it.
