2 weeks ago
2 weeks ago
2 weeks ago
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
2 weeks ago
hi @PardeepSingh looks to me a sim card setup problem on the system
Start with a reboot and Reset all networks
if same, you need to ask support agent to refresh your account
you can submit ticket by direct message:
https://productioncommunity.publicmobile
2 weeks ago - last edited 2 weeks ago
@PardeepSingh you might have to change APN settings to this for PM to work
APN settings
adding does the PM SIM card work in your phone ?
