less than 15 points
ThinkJina
I only have around 10 points, can i redeem now?
9 REPLIES 9
hi @ThinkJina then $15 bill credit is really the only thing you need
They used to have points for jackpot entries but they have not got any for over a year.  I don't think they will bring it back
@ThinkJina
There are a few Add-on and LD calling from 5 to 10 points. Also, there are promos with 0 points.
Just login to your account then go to Rewards tab>Browse Catalogue.
But if you want a $15 credit…the minimum is 15 points.
ThinkJina
i checked the rewards list, can't find anything to redeem. I have Canada-US plan, no need for roaming
i use Whatsapp to call, so, Long Distance addon is no use to me
hi @ThinkJina not sure if you are planning to leave, but if you leave , all the points will be a waste
ThinkJina
not good and not flexible.
Rastin
You need 15 to get $15 off your bill but you can buy things like us min and the like with them for less.
hi @ThinkJina
sorry again, points are not transferable either.
ThinkJina
then can I transfer to friend?
Sorry @ThinkJina you have to redeem 15 points at a time.  No partial redemption
