Number
08-18-2022 02:35 PM
08-28-2022 03:10 PM
@Kiyanna If you're still stuck try adding the number as if it will be dialed long distance: i.e. +1 before your number. For example +18554782542
08-18-2022 08:58 PM
Perhaps try going to the Support section of those websites (if available) and see what they say about your phone number issue @Kiyanna .
08-18-2022 06:43 PM
@Timer wrote:
and tried use browser from computer,and clear cache and cookies and use one page inPrivate mode,
This is unrelated to the concerns of the customer.
08-18-2022 06:41 PM - edited 08-18-2022 06:48 PM
@computergeek541 my mistake info.
if you active new number sometime will be take 5 to 10 days to recognized in system.
08-18-2022 04:35 PM - edited 08-18-2022 04:36 PM
@hTideGnow wrote:still have quiet some trouble
Quite? 😬
08-18-2022 02:57 PM
HI@Kiyanna Many sites have that issue?
and which area code is that. I think BC area code 672 still have quiet some trouble
08-18-2022 02:47 PM
Do you have a phone number with a new area code? Until the website updates their list of new area codes there is not a lot you can do other than request that they do so.
08-18-2022 02:42 PM - edited 08-18-2022 02:44 PM
@Kiyanna hi what websights are you referring to? is it a new area code?are you talking about short codes?
