01-13-2024 02:57 PM - last edited on 01-13-2024 02:58 PM by computergeek541
I setup a new account and i transferred number from another provider however i cannot receive calls or text messages i can make calls.
01-13-2024 08:13 PM
@Truck128 Have you tried contracting the Porting team regarding your transfer issue? They should be able to help you resolve the problem.
01-13-2024 03:10 PM
I followed the steps when i setup my public mobile sim and the provider was aliant
01-13-2024 03:06 PM
Can you outline for us how you went about transferring the number from the other provider @Truck128 , and which provider you moved here from?
01-13-2024 03:01 PM
@Truck128 I’ll send you the porting team number private message . They can give update on the port or retrigger it if needed
01-13-2024 02:58 PM
@Truck128 wrote:I setup a new account and i transferred number from another provider however i cannot receive calls or text messages i can make calls.
Did you remember to leave your old carrier's SIM card in your phone and reply "YES" to the text message for number porting approval?
