Thursday - last edited Thursday
For some reason I'm not receiving incoming calls. I can call out and text but no one can call me. It's going right to voice mail. Ive shut my phone off and restarted several times. Any suggestions would be appreciated.
Friday
@BeaB, I would open a open a ticket through the Chatbot, maybe there is something on their end they can do: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
Friday
My phone only uses 3G. I tried everything else multiple times, nothing is working.
Friday
@BeaB, have you tried the suggestions in this thread?
It seems a temporary fix is to change your Voice & Data (iPhone)/Network mode (Android) to use 3G, or you can try toggling airplane mode off and on or try shutting down your phone and power back on. TELUS is still having some outages. You can have a look on the outage map https://istheservicedowncanada.com/status/telus/map
Friday
I am having the same problem. Cannot receive any call, they go to voice mail automatically. I am in Nova Scotia.
Thursday
Sounds exactly the same. My husband's phone is working perfectly fine. We've never had an issue with PM either. Hopefully they get it worked out soon!
Thursday
I'm in Moncton, 24 hours now without incoming calls; text messaging works but is very slow, up to a 10 min delay. can call out ok.
Phone reset- yes
Sim moved to another phone- yes
all the normal stuff tried with no effect on the problem
Have another Public mobile phone at same location working fine.
First time in years I've had problem with PM, I don't even know how to report a problem???
Thursday
How did I switch to 3g this is all I see.
Thursday
Yes I totally shut it down. I guess I'll see what tomorrow brings. Thanks for the help!
Thursday
likely due to the outage then. Someone earlier today said that they shut down their phone (not a restart) and then started the phone and then it began to work again. I mention the "not a restart" part because they tried numerous restarts but it didn't work
Thursday
I'm in New Brunswick.
Thursday
I'm an existing customer. This just started today.
Thursday
major problem today. You might not be in Quebec but look like you are affected by the same outage
Change network mode to 3G , some said it resolves the problem for now
Thursday
Telus reports some problem with their networks in Quebec and some parts of Ontario....are you in those areas ?
Thursday
@Nikkirenn1, There seems to be a TELUS network outage that has been going on all day, lots of customers have been reporting it. Check the outage map for me detail
Thursday
@Nikkirenn1 Are you a new customer, or an existing customer and this only just started happening?
