01-28-2022
11:12 AM
01-29-2022
10:24 AM
Dunkman
Hi,
I am having some problem that I don't really understand what the root it. I am trying to call a phone # and there is a message that says "cellular network not available".
I am also unable to receive phone calls or texts. And I cannot text either. Does anyone know what the problem is?
Thank you,
Virna
01-28-2022 12:23 PM
I've had a customer who had the same issue. Turns out her payment had not gone through, and her plan did not renew. If this is anew sim card, I would try and see if the sim card works in a different phone. If it works in a different phone and not yours, then your phone may be carrier locked. Hope this may help!
01-28-2022 11:23 AM
Most likely your phone lost connection with cell tower.
Reboot your phone or try airplane mode off/on.
Let us know if any suggestion (from others and mine) helped you out!
01-28-2022 11:23 AM
Was your renewal last night? Call 611 to find out your account status. If your autopay failed you will have to make a manual top up payment by choosing "other" amount and confirming and submitting your payment.
01-28-2022 11:17 AM
HI @vdeganis Check if your phone showing connected to PM network on the top of your phone screen.
Try to reboot the phone once.
If fails, try to change the network to 3G Only and see if it works
Also try to reseat the SIM if fails
If all fail, check if your phone is blacklisted: https://www.devicecheck.ca/check-status-device-canada/
01-28-2022 11:13 AM
It sounds like your phone is not being able to connect to the cellular network. Have you tried turning off your SIM, removing it from the phone, putting it back, and then powering the phone back on?
You may also try using your SIM in another phone temporarily to see if that resolves the issue.
