03-19-2020 10:07 AM - edited 01-05-2022 11:10 AM
I’m not able to pay my plan with everything that is going on. Is there another way to pay? My plan ends in 2 days and I’m beyond frustrated. There’s nothing wrong with my card I’ve checked my end.
03-21-2020 01:40 AM
@NataleG ding.com is currently waiving fees...if that helps.
03-20-2020 11:01 AM
One less thing to worry about....
AE_Collector
03-20-2020 06:03 AM
Got it to work after setting up auto pay like suggested!! Thank you
03-19-2020 09:39 PM - edited 03-19-2020 09:40 PM
I usually prefer to know when my bills come in and pay then but it's worth getting $2 off each month by signing up with autopay so I do that. I would pay every month regardless, so it doesn't make sense not to. Bonus is you don't have to ever worry about your phone bill!
03-19-2020 02:01 PM
Set up AutoPay!
03-19-2020 10:38 AM
Hey @NataleG ,
If you are having issues with one card you can certainly try different cards to make the payment via 611.
Cheers
03-19-2020 10:36 AM
"I’m not able to pay my plan with everything that is going on. Is there another way to pay? My plan ends in 2 days and I’m beyond frustrated. There’s nothing wrong with my card I’ve checked my end."
@NataleG If you are already on Auto-Pay and want to make a onetime payment try using the custom amount field instead of the amount owing.
If that doesn't work then you can purchase a voucher online using recharge.com and add the funds that way until the cc issue is resolved.
Note: When entering a credit card info for postal code do not enter any spaces. Also do not use the unit number field even if you live in an apartment or condo and use a desktop browser if you can.
Hope this helps!
03-19-2020 10:24 AM
Yeah there are several variables here.
What is the exact situation you've having?
Is there a payment card registered?
Are you trying to change it?
There are also online vendors of vouchers. But they cost a small amount more than if buying from a store.
But this is another thing to say to the company that they really oughta be able to take Paypal payments.
03-19-2020 10:22 AM
If you are not setup with autopay then you could either buy a voucher and call 611 or use recharge.com.
03-19-2020 10:20 AM - edited 03-19-2020 10:24 AM
Are you set up for Autopay with your card? If so, it will all happen automatically as your plan renews. Are you a new customer to PM? Has Autopay worked in the past or do you prefer to add funds via your Credit Card before renewal?
AE_Collector
