02-28-2022 08:33 AM
Hi, I travelled from Thompson to Winnipeg but I'm not able to make and receive calls. I did everything restart my phone, changed SIM slot etc etc but it still not working.
02-28-2022 11:11 AM
@Yummy : 3G = WCDMA = UMTS = HSPA. 4G = LTE
From sheytoon:
Minimum recommended phone specs:
Also from sheytoon:
Telus current LTE bands are (in order of band number):
02-28-2022 11:08 AM
@Yummy this is 3G
02-28-2022 11:01 AM
@softechamazing info provided!
PM's phone compatibility page (https://www.publicmobile.ca/en/on/get-help/articles/check-your-phones-compatibility) does mention these frequencies but very briefly.
PM uses term HSPA while you use LTE.
Is there any standard or could you provide some handy table with all different frequencies and band names?
02-28-2022 09:41 AM
Some technical background with the Winnipeg/Brandon issue
Telus uses their own network entirely in Manitoba and does not use the shared Bell/Rogers network.
Telus does not have 3G B5 (850 MHz). So, voice calls on PM must use 3G B2 (1900 MHz). So, voice call would not work if the phone either does not have 1900 3G at all or it is out of Telus 3G coverage.
Data, SMS/MMS and voicemail indicator still works because it can be delivered on LTE, but the actual voice calling still requires 3G 1900.
02-28-2022 09:35 AM
To help with troubleshooting, if you're able to place your Public Mobile SIM card in a different device try that to see if a different device has the same issues.
If so, then you'll know it's related to public mobile service and not a device issue.
If it is, contact the customer support agents for further information and guidance.
There are 2 ways to reach them:
You’ll see their reply in your Community private mailbox in the envelope to the left of your avatar
02-28-2022 09:18 AM
Do you have other services (SMS/Internet).
Could be some issues with cell towers in Winnipeg?
Do you have anybody close by with cell phone, PM or different provider to ask about their service?
02-28-2022 09:14 AM - edited 02-28-2022 09:17 AM
@gaurav_chandel1 What kind of phone you have?
Winnipeg and Brandon area has reduced voice coverage and not all area has both the bands used for voice delivery.
"Public Mobile here. As of March 16, 2021, our Prepaid network in Manitoba will be changing and select areas of Winnipeg and Brandon may experience reduced voice coverage. Data speeds will remain unaffected. "
You data will not be affected. One workaround is to download a VoIP app such as TextNow or Fongo to make calls and receive calls with the VoIP app.
