No voicemail
smerry
Hi,
I just switched my plan to the $40/15gb and now I'm having trouble with my voicemail. When I receive a phone call it states that my mailbox is full.  However, when I check my messages, it is empty.
2 REPLIES 2
Nezgar
@smerry wrote:
Hi,
Hmm, sounds a lot like the issue mentioned in another post in the last few minutes - check out responses here as well: https://productioncommunity.publicmobile.ca/t5/Get-Support/Voicemail-states-it-is-full-but-in-fact-i...
Did you port in your number to Public Mobile recently?
First try resetting your conditional forwarding by dialing ##004#
Also inquire which carrier the callers are calling from. Test calling from various carriers, including a free TextNow app account if you don't have access to other lines.  I wonder if your callers are with your previous carrier, and they are still routing your calls to your previous providers voicemail service...
diamondjoeg
It must have been an issue on their end.  I was talking with CSupport and I heard nothing back from them for last two hours, however it just started working again.
