11-11-2022 01:06 PM
I switched to the $40/15GB plan a few days ago. I set the plan to change on the renewal date, which was Nov 7. I was charged the new rate, but the portal still shows the old plan. It's been 4 days already.
Anybody has the same issue ? Should I contact the mods ?
11-11-2022 02:48 PM
@xoy74 I read that clearing the cache has already solved your issue, but I just wanted to add that next time if you see out of date information you can try just clicking on the little circle-arrow in the bottom right corner of the widgets/sections in the My Account portal, which should update that particular section. Should be a quicker/simpler solution:
11-11-2022 01:11 PM
Thanks ! Showing up correctly after clearing the cache.
11-11-2022 01:08 PM - edited 11-11-2022 01:08 PM
Try logging on after clearing browser cache and cookies, and also use an incognito tab.
Also, when logged in, tap the little refresher icons located on the self-serve landing page. You may be seeing a cached version of the page.
11-11-2022 01:07 PM
@xoy74 No worry. The new My Account site has quiet some cache issue. What you are seeing could be outdated, cached info
So, login My Account again using Incognito mode, you can then see the correct info and you should see the new plan there
Always use Incognito mode to check My Account for now, until the cache issue is resolved.
