01-03-2023
09:59 AM
01-03-2023
10:01 PM
computergeek541
Since I received my used phone from PM my Voicemail has never worked when using the Voicemail button in the lower right of the keypad . It does not seem to dial at all but does provide an Error message.
It is the correct number, I have rebooted my cell phone, I have tried turning Airplane mode off/on. I have searched this Community and tried previous suggestions to no avail.
Would be interested in a solution please?
01-03-2023 11:22 AM
@Chuckwagon 16.2 is the most current iOS at the moment
01-03-2023 11:17 AM - edited 01-03-2023 11:18 AM
@Chuckwagon wrote:Ok thanks y’all.
I used part of your solution and put my own cell number in, not a number from the link provided.
Only remaining issue is that I do not get a red dot over Voicemail tab to notify me that I have a new voicemail.
Go to your iPhone 8 Plus Settings >Phones>Notifications: enable "Badges"
After settings, the red dot should show up on voicemail tab if you have voice mail.
01-03-2023 11:15 AM
Thanks,
now when I press and hold 1 on the keypad it does dial my cell number so that is great.
01-03-2023 11:13 AM
Thanks again.
My IOS Version is 16.1.1 on IPhone 8 Plus so I believe that is current.
01-03-2023 10:56 AM
Check in your phone what voice mail access number is assigned to number '1'.
Call access number from your or any other phone to confirm you can access it. Be aware that vmail has to be set up very first time from your cell phone.
01-03-2023 10:37 AM
@Chuckwagon you should put one of those VM numbers for a more direct calling, it should connect faster
For the red dot issue, are you on the latest iOS? It looks like it is a bug with the current iOS, there have been many reporting this problem. You can try to update Carrier profile , but likely you have to wait for the next iOS update and hope this issue will be taken care by Apple at that time
01-03-2023 10:32 AM
Ok thanks y’all.
01-03-2023 10:03 AM - edited 01-03-2023 10:03 AM
try to manually set the VM phone number like this
Click the Phone icon.
Choose Keypad.
Input *5005*86*13065804001#.
Press Call to program the number.
"13065804001" can be replaced with any of the voicemail access numbers on the following link.
01-03-2023 10:02 AM
@Chuckwagon @Try your SIM card in a different device and see if it works might be your phone in that case you will need help from agent , I’ve also heard of the voice mail not getting notifications on the newest iOS update aswell but if you need help from agent here’s how
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
