03-05-2023 10:11 AM
Hi, my call/text stopped working last night. I have an iPhone, and it can read the sim card but can't get any signal (been shown SOS mode, which means it can read the carrier info but doesn't have signal).
To make sure it's not my iPhone issue:
I tried my friend's VIRGIN sim card, it works on my phone.
However, I tried my boyfriend's card (also public mobile):
His sim card doesn't work on my phone either.
BUT, his iPhone reads both of our sim cards and receives phone calls without a problem. ( it means my sim card and plan work).
Please help, it seems like my iPhone doesn't have a problem, and my sim card and plan don't have a problem. So, why it didn't work on my iPhone??
**I checked my plan is active**
03-21-2023 10:57 AM
@xuxy0919 the phone was not purchased from PM? Since it is not from PM, they wouldn't be able to help
Where you bought it from? If you are lucky, you got from marketplaces backup by big names like Bestbuy or Walmart or eBay etc, they might be able to help refund you the money after you open ticket with them (they still cannot help to take it down from the blacklist). But if it is a private sell, likely you are out of luck
03-21-2023 10:50 AM
Ok, I understand. Is there any fraud center that will help with solving this situation so i explain my situation and appeal this action? Thank you
03-18-2023 11:42 PM
@xuxy0919 wrote:And if it's blocked by carrier. Would public mobile be the carrier to unlock it?
Only the carrier who added it to the national lost/stolen lists could do that. You wouldn't be able to request this yourself as that would defeat the purpose of not allowing found or stolen devices to be used.
03-18-2023 11:37 PM
03-18-2023 11:37 PM
Yes, I talked to Apple. They said the carrier needs to unblock it.
How do I know if this iPhone is black listed by a carrier or apple?
How did the scam guy able to lock my phone if I was the first one to register this phone?
I want to know how did this work to learn.
03-18-2023 11:32 PM - edited 03-18-2023 11:33 PM
03-18-2023 10:59 PM
Sorry, buyer beware. Always check the IMEI on before handing over your hard earned cash:
03-18-2023 10:55 PM
What if i am scammed, anyway to appeal this?
03-18-2023 10:45 PM
Only the original owner can have it un-Blacklisted at the Apple Genius store.
03-18-2023 10:16 PM
Hello Dunkman
After 2 weeks of struggles, I realized this phone was on the national blacklist but it was not out of my action. I think i got scammed while purchasing this phone.
I went to the Apple store, it shows this phone is from the carrier of Virgin, I went to Virgin, then they say this phone is blocked by Telus. So I went to Telus, they found the record of this phone with my phone number on it and it shows it's blocked. Telus employee said it's maybe because I used public mobile so it shows up under their system.
I have all the evidence proving I paid for this phone and I am the victim. If I offer you my evidence and IMEI, would you be able to unblock it for me? Please help. Thanks
03-05-2023 11:43 AM
Does your data work? Text work?
Any recent IOS updates?
Which model iPhone? Was it purchased via another mobile company?
Interesting case. Please keep us updated on any fixes/solutions.
03-05-2023 11:32 AM
Click on 3G to disable 4G/LTE.
03-05-2023 10:31 AM
I don't see where I can disable VoLTE in my iPhone cellular setting. it only allows me to choose between LTE or 3G, there's no disable option.
From the first link you sent me, it seems like already has been resolved. But it doesn't work on mine.
I have already sent a message to CS_Agent. just now.
I reported the issue last night already, CS_Agent said he/she refreshed the network, ask me to reset the network setting and restart the phone. I did exactly. but still didn't work for me.
Any ideas?
03-05-2023 10:17 AM
@xuxy0919 - has this just happened within the last 5 days, and services were working fine until that point?
It does seem to be related to your device with all the testing you did.
Wonder if you were affected by this issue: https://productioncommunity.publicmobile.ca/t5/Announcements/Resolved-Service-Impacts/td-p/955119
Do you have VoLTE enabled on your iphone? Try disabling it.
If still issues, connect with a CSA.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
