08-08-2023 09:03 PM
Since this afternoon I was not able to call/text, it shows bars but no LTE/internet, Search Networks show only ROGERS networks. Is the tower down?! Is there a way to find out? Thanks!
08-09-2023 12:13 AM
which area you are in?
@Justi who is from port elgin Ontario is having the same issue, the phone only sees Rogers network
08-08-2023 09:38 PM
@recaptcha instead of *611, call 1.855.4PUBLIC, enter 1 for English and then enter your phone number, check if the system cam locate your account
I so, try Reset All Networks and see if it works
change to 3G only and see if it works
08-08-2023 09:37 PM
@recaptcha You can submit ticket with support see if there’s something they can do in there end .
private message To CS_Agents click
VVVVV Link below VVVVV
08-08-2023 09:35 PM
No, it's not my renewal day, and my cc is valid. Can't dial *611, it shows 'Emergency call only'.
08-08-2023 09:29 PM
@recaptcha Does today happen to be your renewal . Is your credit card expiry still valid ? Can you log into your account is it active or on hold you can also dial *611 to find out
08-08-2023 09:27 PM
Dumb answer of course. Try read the question first. And if you plan to be so rude don't bother replying, I can survive without it.
08-08-2023 09:23 PM
Dumb question of course. Did you try rebooting your phone and then go into networks settings to see if Public Mobile was there?
08-08-2023 09:12 PM
