04-02-2023 08:28 AM
5 days ago I joined PM ,I ported my number. I got the freedom mobile request to port number and said YES. I have LTE service but no cellular service I live 500 meters from a bell tower . I have turned off and on and remover the sim so many times , the service has been reset by PM my phone is Motorola g power 2021. Any help would be appreciated.
ps. The call tries to go through then the LTE and cell lines drop and call ends with a message
Cellular network not available for voice calls.
04-16-2023 09:15 AM - edited 04-16-2023 09:17 AM
@2Irish wrote:got the new sim card in and same issues ,it is a brand new bell tower could it be only letting bell mobility calls go through. it is mhz700 mhz 850
@2Irish PM using Telus and Bell towers and all calls will go through as long as it is connected
have you open a ticket with PM support yet?
Also, you tried clicking "reset all networks" on your phone?
For Preferred network type or Network mode, make sure you enter choose Automatic , you can try to choose 3G Only , definitely not to choose 5G only (if there is such choice)
04-16-2023 09:04 AM
04-02-2023 09:39 AM
@2Irish could it be that the bell tower near you is a new one with no 3g. All the newer towers only have lte and 5g. But saying that and your account is new then volte should be enabled. Check your phone to see if there's any volte settings and if they're enabled. If your phone does support volte and is enabled then you should message the cs_agent to make sure everything is provisioned right. Good luck!
04-02-2023 09:36 AM
@2Irish wrote:Freedom service is gone.
Porting should be fine and completed.
It could be an account provision issue versus the Public mobile talk issues with the VoLTE roll out. Several customers have issues with calling in the last week or so.
Did you try adding 1 or+1 in front of the area code?
Likely need to contact customer service agent.
04-02-2023 09:26 AM
But with LTE, can you still make outgoing calls?
And do you have another phone around you can test the sim card? While this tests if it is a device issue, it could also force a sim reprovision and it could resolve the issue
I would also suggest you to try to drive closer to the Bell towers and see if incoming and outgoing calls both working. Or go around different part of the town to test if you are going out
It does look like it could be sim card provisioning error. So, before you go out, why not open a ticket with PM support and have them confirm
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
04-02-2023 09:24 AM
04-02-2023 09:22 AM
LTE Texts and data sms all work . 3g nothing .
04-02-2023 09:09 AM
sounds like a porting issue
04-02-2023 09:04 AM
What about texts? Are you able to receive texts? Send texts?
You could try your Freedom mobile phone to see whether it is still working.
It might be a stuck port, but need more additional information.
If it is only a calling out issue, try adding 1 or +1 in front of the area code.
04-02-2023 09:04 AM
@2Irish please still call the number I sent you (PM porting support team) to confirm.
Also, what you can do in the mean time is to change the Preferred network type or Network mode to 3G Only and test if you can receive incoming calls on your PM sim card
04-02-2023 09:02 AM
No calls . I called freedom they said porting was complete
04-02-2023 08:59 AM
@2Irish So, you can make calls but no receive calls? did you receive any calls at all on your PM sim card since joining? Wonder if the porting did indeed completed.
There is a porting team to call and confirm. I will message you the number via the Community inbox. Please call the number and check first.
