05-26-2023 05:20 PM
Phone : iPhone 13 Pro
I just purchased the 3 month 5g/150gb plan but I am unable to access 5G. I am located in Bridgewater Nova Scotia. Is there no 5G here?
05-26-2023 09:07 PM
even though you are unable to access 5g, you should still have access to 250mbps speeds through lte. you can do a speed test to confirm. however, it may consume close to 500mb+ data
05-26-2023 05:28 PM - edited 05-26-2023 05:37 PM
@GaijDelaneu wrote:Phone : iPhone 13 Pro
Check this PM coverage map: it looks like only 4G/3G
https://www.publicmobile.ca/en/on/coverage
05-26-2023 05:25 PM
05-26-2023 05:24 PM - edited 05-26-2023 05:24 PM
@GaijDelaneu Check this map with your area to see what coverage is available to you. If I look up Bridgewater it looks like only LTE at the moment. It's constantly changing so keep checking back.
05-26-2023 05:23 PM
@GaijDelaneu Reboot the phone first. If you haven’t already , also not sure bridgewater has 5G Halifax does , so when not in the city at this point you may have to rely on 4G /LTE
