No Data after U.S. Data Add-on
kalpesh7
Hi,
I redeemed Rewards points for U.S. Data (15 days) two days ago.
I'm in the U.S. now but cannot access the data.
I'm attaching the email confirmation I received below:
kalpesh7
I've tried all the proposed solutions. However, nothing seems to resolve this issue.
@kalpesh7
Try AT&T. I forgot to tell you to reboot your phone by powering off then back on for both network.
kalpesh7
@BKNS27 That still didn't work. I'm already connected to T-Mobile.
Here are the Network settings:
@kalpesh7
You will need to manually connect to AT&T or T-Mobile Network.
Also enable VoLTE in Voice and Data setting if you are calling.
If that didn’t work. Contact a CS_Agent at:
