07-06-2016 04:20 PM - edited 01-04-2022 02:49 PM
08-14-2017 03:48 PM
@jyotsananorth did you complete both steps of the 2-step purchase process? Check if you have $30 of "available funds" amount showing on the overview page in self-serve. If you do, then you need to go back in and do the purchase process again to use those funds and add the add-on.
If you did do both steps, have you rebooted?
08-14-2017 03:21 PM
Hi there
I paid for 1gb add on my plan
However its not working.
07-25-2017 03:16 PM
07-25-2017 02:33 PM
I'm attempting to reply to your PM, but it seems that you have PMs disabled and I cannot send you a message. This would probably be helpful in this thread too. 😃
Thanks!
07-19-2017 09:23 AM
Hello Bin,
Thank you for reaching out to us 🙂 . In order to assist you, could you please provide us in private message with your account information (SIM card number, phone number)?
Note this is a public post, please do not publish your personal information.
Awaiting your response, have a good day!
Aïssata_B
07-19-2017 04:08 AM - edited 07-19-2017 04:08 AM
You shouldn't post that infromation here. You just posted your phone number and some of your account information for anyone in the world who wants to see it. You can edit your messages so that information is no longer viewable.
07-18-2017
11:21 PM
07-19-2017
09:13 AM
Aïssata_B
hi i just turn from fido to public mobile,i can call out,but i can't receive any calls.my
SIM card number is xxxxx
phone number is xxxxx
11-05-2016 08:22 PM
Thanks Luddite. FIDO sim still works so a port-in stuck issue. I have sent a private message to Mary_M
11-05-2016 06:13 PM
11-05-2016 06:11 PM
11-05-2016 04:30 PM
That is normal behaviour until the port-in completes.
Suggest you wait another 2 hours in case the port-in completes. If your Fido SIM still works then, your port-in is stuck. Follow the procedure outlined here: Contact moderator
11-05-2016 04:07 PM
07-07-2016 10:20 AM
Hello @Sigma959,
Now that your Fido account has been reactivated, I will be able to resubmit a new request. Could you send me your Fido account number by private message? Please double check it, as the first request failed due to incorrect information.
When a port request is submitted, and not successful, the customer will usually find himself/herself stuck with a mixed service: all outgoing calls/texts can be done through the new provider's SIM, but all incoming calls/texts can only be received on the old provider's SIM. The fact that your Fido account was still active, shows that the port wasn't completed: when the port is completed, your account will the old provider will be automatically closed.
Cheers,
Kalla
07-06-2016 08:10 PM
07-06-2016 07:39 PM
With your Fido account active again you should be able to receive calls with the Fido sim installed.
If that is not an option and you need to make phone calls try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi.
You may be able to try porting again from your self serve account, but I'd be inclined to wait until a modderator can assist you tomorrow.
07-06-2016 07:19 PM
07-06-2016 06:57 PM
Hi @Sigma959. This is frustrating, indeed. You can make/send calls and texts because that portion doesn't depend on the porting, only you inbound calls and texts. It does sound like, despite the text you got that the port was completed, that it wasn't properly completed.
@Kalla_A or @Mary_M or @Shazia_K can you please step back in to assist @Sigma959?
07-06-2016 06:50 PM
07-06-2016 06:46 PM
07-06-2016 05:29 PM
@Sigma959 Sorry you've run into a probelem, but you are well on your way to getting this resolved.
However, as you have discovered, others need to know that they should NEVER cancel their old account until the port is complete. That way they can always continue using their old carrier if there is a delay.
Hang in there.
07-06-2016 04:26 PM
Hello @Sigma959,
Welcome to Public Mobile!
If you ported your number, and are unable to receive incoming calls and texts, this means your port wasn't successful. Please contact your old provider, and ask them to reactivate your account. We will not be able to complete the port otherwise.
Once your account is reactivated, please send me the correct account address. Ports usually fail due to incorrect information. You can send me the information by private message, and I will resubmit your port.
We will get this sorted out 🙂
Cheers,
Kalla
