New sim showing temporarily unavailable
Monteynem
Hi I setup a new account and purchased a new sim.  But the status of public mobile is showing (temporarily unavailable).  And I cannot call or text
9 REPLIES 9
I'd still try a network reset and restart your phone. Sometimes it can be a little finicky.
Just to confirm, did you try your SIM card in a different phone?
Monteynem
Hi.  No this is a brand new phone and brand new sim .
@Monteynem
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send  a  private message   To CS_Agents
Did you by chance port over another number from another carrier or just pick a number with PM?
If the phone was used with a different carrier before, you may need to do a network reset. Do you know how to do that? If so, just go into network settings and reset then restart phone.
Monteynem
Yes I installed the app and if appeared to work..  the only thing when I tried to login it wanted .  Full access to something and would send me a code to the new number but it didn't work..   I can't make or recieve phone calls or texts
Monteynem
Hi. Yes I restarted..  also removed sim..  tried again.  Nothing.
I registered it and have a phone # but . It's not working
@Monteynem  Did you activate the sim card on the public mobile app ?nit website you need the app to activate
Chalupa_Batman
Hello @Monteynem
Have you tried to reboot? Did you register your SIM card in your profile? If so, have you tried the SIM card in a different phone?
