Unable to use data when there is no wifi
2TV
When I’m away from home wifi, I cannot use google search or other search engines or send email…because I got the message: “no internet connection”. I have a lot of data left. What should I do to be able to communicate without wifi?
8 REPLIES 8
2TV
Thanks. Will do.
How do I “reset the network “?
@2TV   Try turning airplane mode on, wait a few minutes, then turn it off.  You could reboot the phone also.  If that doesn't work, then reset network settings is in Settings > General > Transfer or Reset > Reset > Reset Network Settings.  If it still doesn't work then contact customer support using the chat/message icon bottom right of this page.  If the chatbot doesn't seem to be working then send a private message using this link and watch for a reply from an agent at the envelope icon top right or tap your avatar for Messages.
2TV
iPhone 11 Pro Max. Thanks.
2TV
Data always on. How do I reset the network settings ?
HI @2TV
what kind of phone you have? tell us before we can help more
2TV
Yes, I just joined PP recently. I have turn on and off my phone many time. How do I “reset the network “?
Hollister
@2TV
Have you tried resetting your network settings and checking your apn settings? Is your data on?
HI @2TV
are you new subscriber or here for some time?  what phone do you have?
can you try to reboot the phone and test.  If still cannot connect data, try click Reset All Networks and test again
