04-21-2024
06:40 PM
04-22-2024
01:12 PM
Dunkman
04-21-2024 08:48 PM
@MichaelD1 - Are you using eSIM or Physical SIM?
eSIM cannot be transferred to another device with PM - you will have to login and get a new one within the Public Mobile app.
Physical SIM should have no issues.
Also when you get a new eSIM you will not lose your phone number.
If you need assistance with a PM support agent, contact them here:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
