New line in SOS mode
Rachel12345
Just moved from Bell today and approved the account transfer. Activated eSIM when setting it up. Now phone is in SOS and I do not see any eSIM when I go to Settings/cellular on my iPhone 11. Still showing Bell
7 REPLIES 7
Rachel12345
it worked! thank you!
hi @Rachel12345 dont delete the Bell eSIM yet, just disable it.  Click on it and toggle off "Turn on this line"
hi @Rachel12345 since you don't see any eSIM, it is not a porting problem at this time
did you get any Welcome email from PM? there is a QR code for eSIM , scan and install
if that does not help, you will need support agent to send you the eSIM
you can  submit by direct message:
Rachel12345
I tried, it didn't work
Rachel12345
How do I delete the bell eSIM?
Chalupa_Batman
Hey @Rachel12345
Did you get the text message from Bell asking to port over to Public Mobile? And you said YES? If so, then you can delete the Bell eSIM. Are you use you installed the Public Mobile eSIM correctly? If not, you may need to get a hold of a CS Agent to help you get a new one. Bottom right corner is how you reach them in the chatbox. It's not live but they will get back to you eventually.
hairbag1
@Rachel12345
let's try rebooting your cellphone to see if that helps.
