4 weeks ago
- last edited
4 weeks ago
computergeek541
How to know if my transfer is complete (and that i'm not using the temporary line anymore) ?
4 weeks ago - last edited 4 weeks ago
@n001 wrote:How to know if my transfer is complete (and that i'm not using the temporary line anymore) ?
Any temporary phone number is actually gone as soon as number porting has been requested, and if you asked for number porting during the activation process, there was never any temporary phone number. The actual number porting for a wireless phone number is usually done within a few hours though.
4 weeks ago
Simple. Can you make and take calls? Can you text and receive text messages? Can you use data? And finally, the most important and easy way to test.... if you place your old providers SIM card in the phone, do you still have service? If no, then your set!!! If yes, there may be a problem.
