01-16-2025 10:40 AM
01-16-2025 11:26 AM
Ok. Thanks to everyone for the help. I finally went to setting>reset and chose >delete all eSims. The phone is now acting like a normal phone with proper network icons and I can make calls. Thanks for taking the time. I listened to all your advice and tried each. Apologies if I seemed to blame PM. Was just frustrated…all the best.
01-16-2025 11:19 AM
hi @Jeff641
go to the Sim Manager screen or Settings-> Cellular and check how many sim showing up there. Maybe post us the screenshot and we can better assist
01-16-2025 11:11 AM
pretty sure your esim still there. delete the Public Mobile esim
what phone do you have?
01-16-2025 11:04 AM
I reset network settings. No change
01-16-2025 11:03 AM
I have physical sim because my port of number failed. Took 6 days to get sorted and had to go purchase a physical sim. So I may have both? eSIM and actual sim.
01-16-2025 11:00 AM
My preferred phone iPhone 12 won’t work. I have a physical SIM card.No dual port. I am actually not sure if I have eSIM. Can I delete ESim? Very confusing and frustrating.
01-16-2025 10:56 AM
so, it is not an area outage.
you have physical sim card , right? Is that iPhone or Google Pixel? or other dual sim phones you have? does the PM esim ever work on this phone you want?
Go to the settings and Reset network settings, this will usually clear up the problem quickly.
01-16-2025 10:52 AM
hi @Jeff641
if it works on the other phone, it is not a PM problem.
for the phone that it does not work, what brand is it? Make sure that phone does not have another sim card there, remove it. If it is esim, either disable it or delete it (but delete only if you are sure). Your Public Mobile sim should be Primary (shouldn't be Travel or so)
01-16-2025 10:50 AM
Is working in my other phone. And network icon is normally. Other phone. In my preferred phone the network icon is split and always shows Primary or Travel prefix in my preferred. Help please.
01-16-2025 10:46 AM
I rebooted twice removed sim. Phone tries to connect but just won’t connect. Will try these solutions. Last week was sos. Is this going to be a problem?
01-16-2025 10:42 AM
hi @Jeff641
is that a new activation or not?
data works? or not at all? you said phone won't connect, so, it is showing SOS on the status bar ?
what phone do you have? physical sim or esim?
Try reboot phone first, try Reset Network settings after. You can also try your sim card on another phone
