08-25-2026 12:17 PM
Hi my access is not working properly. Has there been a downgrade to the system?
4 weeks ago
hi @Lecia what phone do you have?
did you get Reset Network Settings?
if same, submit a ticket here using the same Community login credentials you are using now: https://expert-messaging.publicmobile.ca/guest/chat/
Once you started the Chat, type "Submit Ticket", then "Connect Agent", and it will ask you to login to open ticket
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email" or "Send Voice Message")
Remember CS_agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
4 weeks ago
The issue still exists even with the reboot of my phone. It seems to only work best on WiFi.
08-25-2026 12:56 PM
hi @Lecia no downgrade but just upgraded
so, you have trouble logging in.
If unable to access My Account/PM app, submit a ticket here using the same Community login credentials you are using now: https://expert-messaging.publicmobile.ca/guest/chat/
