New Phones that Support VoLTE
JaY_III
The list of phones that support VoLTE is 2 years old.   How can I find a current method to know if a phone will work or not?    When looking at Samsung "A series" phones for example I see some listed as Canadian and others international versions.   Both look to have the same bands and both say they support VoLTE but will they?
My OnePlus phones for example also support VoLTE on paper, but in Canada they never have.   Pop a T-Mobile SIM in the phone and it all works perfectly w/ VoLTE.
This lack of clarity is making getting a new phone much harder than I would like.   Also the just go buy a 2K flagship to make things work is also not a great solution.  I am trying to get a reasonably priced mid ranger for one of my daughters and would like the phone to work out of the box.
26 REPLIES 26
JaY_III
Just an update as I upgraded another Phone.
Pixel 10 series works after talking to CS.
The IMEI was not in the database, then a few messages back and forth we me explaining  I cant upgrade to a newer model as the phone literally just officially launched that day they sent the ticket off to a tech who fixed everything.
To Verify VoLTE works  (this shows 5G and VoLTE)  check this:
Settings -> About Phone -> SIM Status reports:
Mobile Voice Network Type : LTE
Mobile Data Network Type: NR NSA
Then make a call and check while in call to ensure it stays the same
If you see the following it has fallen back to 3G:
Mobile Voice Network Type : UMTS
Mobile Data Network Type : HSPA+
@JaY_III if you click  Settings , About Phone, Status Information, Sim card status, is the ONS registration showing Registered?
do not buy from Bestbuy marketplace, not sure if Staples' a marketplace or not
Amazon.ca will be Canadian model is sold by Amazon or sold by Samsung, and reliable olif choose those 2
vince90cay
@JaY_IIICanadian model is SM-A356W. I would buy it directly from Bestbuy or Staple... never on Amazon.ca since I want to avoid non-canadian models.
https://www.samsung.com/ca/smartphones/galaxy-a/galaxy-a35-5g-awesome-navy-128gb-sm-a356wzkaxac/
JaY_III
what is the model number? A35 has a specific Canadian market model.  Most from Amazon are not the Canadian model
JaY_III
Yes the Canadian version of the A35 I bought my daughter, Samsung A35 SM-A356W stays on 5G when making calls and does not fall back to 3G like phones that do not support VoLTE on public mobile.
If you buy a non Canadian model of the phone I have no idea if it will work or not.  But the Canadian model of the A35 100% works, so if buying online, make sure you get the correct one.
@JaY_III wrote:
I confirmed the A35 works in the post you quoted, so you are safe getting that one
HI @JaY_III
I believe A35 works here but it cannot use VoLTE on PM network
vince90cay
Hi @JaY_III. Thank you very much for your answer.
When you state that the A35 works, do you mean it's fully VoLTE supported with Public Mobile?
JaY_III
vince90cay
@JaY_III I need a new phone that is VoLTE supported at Public Mobile. I am thinking to buy the Samsung Galaxy A35 5G (Canadian model SM A356W).
Could someone who uses Samsung Galaxy A35 confirm that VoLTE is supported and works on the Public Mobile network?
Thanks for your help
JaY_III
Just an Update as i have been upgrading phones on my accounts:
Google Pixel 8                       -> Works !
Samsung A35 SM-A356W   -> Works !
Both phones connect to 5G without issues directly out of the Box.
When placing a call they both stay on 5G and do not fall back to 3G like other phones.
JaY_III
Thanks for all who answered,  but at this point, i think the answer is clear.
We have no way to know what will or wont work.  Its all trial an error with sim swapping and  testing for yourself.
Not the answer I was hoping to get, but it seems to be what it is.
maurelle
@JaY_III wrote:
reasonable price for a childs phone i would say is about $350.
OnePlus N30 is 300
Samsung A15 is 200 / 265 (once again, will the international verson work? its much cheaper and has the same band support)
Samsung A35 is closer to 500 and i would prefer to stay under that
Moto G 2024 $250
None of the listed phone are 100% confirmed to work with VoLTE.
So I ask again
I can confirm that OnePlus Nord 3 is blocked from using VoLTE on Public Mobile.
If I remember I'll report back in a couple of days on the Moto G Play 2024. A friend just got it, but they are not using PM anymore, so will have to go over and try my SIM.
@JaY_III  How can I find a current method to know if a phone will work or not?
Find a family member or friend (or a store?) with a phone you are interested in and who will let you play with their phone, replace their sim with your PM sim, turn on cellular data, turn off wifi, make a phone call.  If it stays on LTE during the call you have VoLTE, if it drops to 3G you don't.
I'm guessing you want it to be a VoLTE phone because you travel to the USA?
@JaY_III if phone for kids, get Samsung A1x series or Moto
I wouldn't care VoLTE for now. PM not going to stop 3G for voice any time soon. And by the time they are stopping 3G voice, pretty sure most VoLTE phones will be whitelisted
JaY_III
OnePlus N30 is 300
Moto G 2024 $250
So I ask again
@JaY_III the A55 will come to Canada , just need another month or so
Would you consider the S23FE??
DennyCrane
The Pixel A series definitely have gotten up there in price. They do have sales though. We picked up some 6A's a little over a year about for $399. You won't get that pricing when they're brand new, but they do come along.
@JaY_III   What would you consider a reasonable price range?
JaY_III
The only Samsung "A series"  listed is the A53.  and Samsung no longer sells the A5x series in Canada.
So that leaves the A35 (no prior version on the list) or the A15, also no prior version on the list.  But what about the ones listed as "Canadian" vs "international" models?
The Motos also have a similar problem.  The ones listed as a "Canadian" variant are all cut down from the "international"  versions and cost more for less.   So no idea what will work or not still.
The Pixel As are still too much money for a kids phone IMHO.
So where does that leave me?   As as what all have suggested so far, its spend more or gamble if it will work
@Meow  I had that happen with another (Tier 1) carrier where the phone was capable of VoLTE but not supported.  The carrier said it was a manufacturer issue, the manufacturer said it was a carrier issue.  I gave up trying to get it working in the end.
Meow
Your phone might support VoLTE (same as mine) but PM did not 'activate' it (or whatever) so that option is not available to me and that might be the same with your phone.
@JaY_III  Would $579 be mid-range, that's what Apple is selling a new iPhone SE for currently.  All iPhones from 8 up get VoLTE on PM.
Chalupa_Batman
Hey @JaY_III
Public Mobile is sadly known in the communication world for their lack of communication. LOL. A lot of information on this website is outdated and obsolete. Keeping up with the times, not exactly their strong point.
Best advice I could give, stick with the brand names. Google, iPhone, Samsung, Motorola. Stay away from the Chinese aftermarket type phones.
That's always been my assumption too. All the new iPhone's work, and every new Pixel (A or regular version) that I've gotten has worked too.
Phil_Adelphus
@JaY_III   The list doesn't seem to get updated but it's assumed that newer versions of what's already listed would get VoLTE.  Non-VoLTE phones will still work in Canada since we still have 3G, unlike in the USA where voice calls are an issue without VoLTE.  There are some Moto G phones on the list, I used to have a Moto G years ago and loved it.
