Network and Connection strength on trains
hadielr
Hello everyone, this is my first post on here. I wanted to ask a specific question about my situation and was hoping to get some answers from anyone here with experience.
I currently take the via rail for work between the london-toronto corridor and often need to hotspot myself on the train to get work done. I was wondering if anyone who had been on the train in that area knew if Public reception is strong and if the network is capable of dealing with my usage while on the via.
Any comments or help would be great.
Thank you!
hadielr
Thank you so much for your response, but Via wifi has blocks on websites I need to use for work, and it also blocks VPNs, so it's not an option.
hi @hadielr
but Via has free Wifi on board
https://www.viarail.ca/en/plan/onboard-train/free-wifi
so, you only needs voice call working on the corridor, which I believe would be decent, sorry, no personal experience
For hotspot, PM does not block hotspot and will work , but again, you can use Via Wifi instead
Dunkman
@hadielr
No personal experience since I live out west.  Hopefully, somebody may be able to answer your particular question.
If nobody does, you could purchase a Public mobile plan and try it yourself.  Do not port your number yet.  Just pick a new temporary PM number.  Give it a try for a few weeks.  If it works, then port over your number later.  If it does not work well, stop pre-authorized payments and let your PM account go suspended after the first 30 days.  Then the PM account will close after 90 days of suspension.
No contract or credit check with Public mobile.  Prepaid.  No surprise charges.
