Price Matching
Ott2023
Looking to port to Freedom for the 34$ CAN-US  50GB plan, as we do lots of cross border travel. Will Public price match for existing customers? The 34$ 50GB CAN-US plan appears to only be available for new customers.
jmjosse
private message @CS_Agent and be very nice...
Dunkman
@Ott2023
What is your present plan?  If it is less than $34/month, you will have a more likely chance for CSA to change. If you are "upgrading" your plan, CSAs may be able to change.  No guarantees.
However, if you are downgrading your plan, way less likely for CSA to change. You can still ask though.
@Ott2023  You can try and ask support sometimes they can help give existing customers the new activation only plans . If not note there’s a 75GB CAN/US plan for $40 available to all
send  a  private message   To CS_Agents
