Network Reset on Light Phone
smncaux
Hello,
Does anyone know how to carry out a network reset on a Light Phone?
Thanks
7 REPLIES 7
and @smncaux   you aware that Light phone is 4G LTE only?
You won't be getting calls on PM network as PM needs 3G to carry voice and Light Phone does not have 3G
@smncaux   Oh really?  Interesting.  I was only aware of android and iPhone devices.  Try googling your device for the network reset options or maybe the manual for this device may have some information?
@smncaux   since Light Phone does not have too many settings, you might want to do a Factory reset then
Settings > Account & Info > Factory Reset
smncaux
A Light Phone is neither an Android or iOS. It is it's own thing so this path doesn't exist for me.
dabr
@smncaux   For android phones, just open Settings>General management/System>Reset>Reset network settings.
You may need to enter a PIN if one is set, then reboot the phone.
This will also remove your WIFI password, so you'll need to reset that as well.
@smncaux   try this:
Go to Settings > General > Reset > Reset Network Settings.
hycm53
