Need to pay bill
03-26-2023 09:03 PM
03-26-2023 09:08 PM
there has been some problem with *611 at the moment
https://productioncommunity.publicmobile.ca/t5/Announcements/Ongoing-Issue-611/td-p/963252
Try calling 1.855.4PUBLIC from another phone and enter your phone number. This is the same as using *611
Or you can also login to Self Serve My Account and pay that way
03-26-2023 09:08 PM
there is still problem with *611 and PM is aware of it
You can keep trying *611 or 1-855-4PUBLIC from any other phone, some people tested and it will connect eventually. So, keep trying and it might work
03-26-2023 09:06 PM
@Kashira2sail wrote:611 isn’t working
Payments can be made in your Self Serve account or by calling 1-855-478-2542.
