09-26-2021 03:30 PM - edited 01-06-2022 03:38 AM
I have. Plan $ 25 / moth with public Mobil from Canada no I am in the US. For six month I need to be able to Text my family in Canada And US . I was chatting with Carlos and he said that I can add $8 /month and change your plan to $ 15 / month to be able to have unlimited Text
please let me know if you can do that for me
thank you
09-27-2021 11:29 AM
There are quite a few apps you can us for the things you have mentioned. The only drawback is that these apps need wifi so you can not really use them on the road. If that is the case you might need to consider another carrier while away.
09-27-2021 10:41 AM
Ideally, if SMS does not need on-time delivery and immediate reply AND WiFi is accessible, TextNow or similar free app is optimal solution. Works like a charm, never failed me so far.
But if real-time SMS is required I guess you can get some temporary US SIM with free SMS. Whatever plan you have with PM, I would lower it to $15 plan with auto-pay if you care to keep PM account and number and rewards (loyalty, etc.).
09-27-2021 10:30 AM
09-26-2021 04:33 PM
Since you are already in the US you cannot use the call forwarding option with fongo. I suggest you check out mint mobile while in the US and suspend your services as described below using the lost/stolen option to maintain your pm voicemail.
Mint mobile has $15/4gb w/free calling and texting to Canada and Mexico.
https://www.mintmobile.com/plans/
Here are the ways to suspend your plan while away. If you dont have a grandfathered or a plan with a specific promotion you can lose then switch to the $15 plan and it will only cost you $15 to maintain your account the entire time you are away.
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. Happy travels!
Edit: Said all this noted the six months in the US time frame blah, blah, blah.....computergeeked...!! That and my dad called me on messenger as I was about to hit post about half an hour ago for the fourth time.
09-26-2021 03:45 PM
09-26-2021 03:38 PM
That's not quite right. It would be $8×10 days×3=$24+$15=$39. You will get free incoming texts with no roaming plan. If you download text now you get free texting and calling while on wifi. If you don't have to text them back immediately that will fulfill your needs without the extra roaming add on cost.
What plan are you currently on? How long are you in the US?
09-26-2021 03:33 PM - edited 09-27-2021 12:06 AM
@SM7 wrote:I have. Plan $ 25 / moth with public Mobil from Canada no I am in the US. For six month I need to be able to Text my family in Canada And US . I was chatting with Carlos and he said that I can add $8 /month and change your plan to $ 15 / month to be able to have unlimited Text
No plan change is needed, but it can be done to reduce costs. You'll need to purchase a U.S. roaming add-on, but be sure to choose one that includes text messaging. And, as mentioned above, roaming add-ons only last 10 days.
09-26-2021 03:32 PM
@SM7 : It would get expensive in a hurry to keep buying the roaming add-ons every 10 days for 6 months.
You might want to look at local service or using voip apps like TextNow that also do voice.
