Need to ask, hypothetical question on the E-Sim
makkahn28
If lets say one has a E-Sim installed on their Phone, and they went on a vacation, and had to install another E-Sim for that trip,
How can one reinstall the Original PM E-Sim back on the phone W/O having to pay for another?
12 REPLIES 12
LitlLdy
@makkahn28 ,
All iPhone models that support eSIM can have multiple eSIMs and use Dual SIM with two active SIMs at the same time.
You can use Dual SIM by using a physical SIM and an eSIM. iPhone 13 models and later also support two active eSIMs. iPhone models without a physical SIM tray support two active eSIMs.
Using Dual SIM with an eSIM
Excellent info
@makkahn28
If you want your eSIM on anothe phone (say you got a new phone OR you wipe your phone and need it reinstalled), you will need to pay for a new eSIM as eSIM can only be installed once.  Most Canadian providers charged that.  And yes, physical sim is eaiser and better in that sense
Now, If One had a Phone that had space for, 4 E-Sims, Though it's one at a time, does the User still need to buy a new E-Sim when returning from Vacation?
No, you don't need to rebuy as long as the eSIM was never deleted from that device.  Setting it to inactive and then set it back to active is ok.  So, key is never delete the eSIM if unsure
That answers the Main Primary Question on  If One had a Phone that had space for, 4 E-Sims, Though it's one at a time, does the User still need to buy a new E-Sim when returning from Vacation
@hairbag1 , That's what I was asking about
As E-Sim is a Newer Format, Need to educate myself on the aspects of E-Sim
Now, though I don't yet Have a Phone that supports E-Sim, In the event I do, Need to ask all these questions
Now, Unlike a Physical Sim, that can be swapped on the fly, and Swapped back with No need to Buy a Replacement, Wished E-Sim was the same though wasn't sure as I was reading a few different PM ppl
s comments on this, so I needed clarification on this
@makkahn28 Most phones with ESIM capability can have multiple esim installed, but only one active eSIM at all time (except iPhone 13 can have 2 active eSIM)
So, you just install the travel eSIM, use the device's Sim Manager to pick that as the active eSIM.  When you are back in Canada, use sim manager to change PM's back to active
@makkahn28  Some phones have ability to have several eSIM at a time but only use one at a time @Priority has 3 PM esims on his Samsung phone but can only use one at a time
add @makkahn28  check out the post about it
https://productioncommunity.publicmobile.ca/t5/Get-Support/e-SIM-Capacity/td-p/1032410
@makkahn28
if you uninstall the original PM esim, you'd need to buy another when you return. Is that what you're asking ?
@hairbag1 That's Not what I was asking
@makkahn28
if you have your PM account using an esim, then travel to ..say Mexico...you'd need a physical sim from Telcel if you wanted to have service in Mex.
Oh, That is a shame
Just saying, wished there was a way, Like, if the QR Code being the only way or something
hairbag1
@makkahn28
you can't do that. You can use a second physical sim though.
