07-30-2023 11:34 AM - last edited on 07-30-2023 11:46 AM by computergeek541
I want to switch my father to Public Mobile. He has an LG B470 flip phone. Will he be able to send/receive calls if a PM sim card is installed? Anyone currently using this phone successfully with PM?
08-12-2023 10:33 AM
Thank you for your prompt response and confirming!
08-12-2023 10:32 AM
Thank you for your prompt response! PM SIM card installed and it worked!
07-30-2023 11:45 AM
Yes, his flip phone will work on 3G at 850 MHz and 1900 MHz frequencies for making and receiving calls.
It will be good until 2025 when 3G will be decommission and he will need a new phone.
07-30-2023 11:42 AM
I don't have one but should work...
3G:
Bands 5(850), 2(1900) |
Put the PM sim in the phone and try it.
