01-30-2023
06:46 PM
01-31-2023
12:30 AM
computergeek541
The porting has been manually done by Porting assistance. However, am still not registered on network. Have PM SIM card # for PM tel #
01-30-2023 08:53 PM
If you have nonpayment for longer than 90 days, you can’t reactivate the old SIM and the old number is lost.
Can we get more detail of what you are requesting?
01-30-2023 06:57 PM - edited 01-30-2023 06:58 PM
On Existing account you can only SWAP SIM, you cannot activate another one.
And porting could not be done without active account and activated SIM, so your statement is a little bit confusing.
01-30-2023 06:55 PM
@Nadia321 if you still cannot connect to PM network, it is a sim card provisioning problem. Please open ticket with PM support, it is an easy fix and they can resolve the issue:
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
01-30-2023 06:54 PM
@Nadia321 wrote:The porting has been manually done by Porting assistance. However, am still not registered on network. Have PM SIM card # for PM tel #
If I understand you @Nadia321 , you cannot activate a SIM card on an existing PM account.
Can you clarify what you're doing? What you've done? And what you're wanting to do?
01-30-2023 06:50 PM
01-30-2023 06:47 PM
@Nadia321 You want to SIM card swap don’t activate and do this in computer only
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
