09-23-2023
01:37 PM
10-15-2023
01:02 PM
Dunkman
Hello - my physical SIM card suffered water damage and I need a replacement SIM (either physical or eSIM) with the same phone number associated. How do I order a replacement SIM and ensure I still have the same phone number?
09-23-2023 01:51 PM
Thank you very much 🙂
09-23-2023 01:43 PM
@FSyd Get a new sim card and sim swap it in your account profile tab like this
SIM SWAPPING profile tabs
Note only do this on lap top or computer/ not mobile device
09-23-2023 01:40 PM
To ensure you retain the same number, log into your self-serve account and under your profile tab you will see the option to change your sim card.
Whatever you do, do not activate the new SIM card as you will be creating a brand new account.
09-23-2023 01:38 PM
@FSyd wrote:Hello - my physical SIM card suffered water damage and I need a replacement SIM (either physical or eSIM) with the same phone number associated. How do I order a replacement SIM and ensure I still have the same phone number?
SIM cards can be purchased at corportately-run Telus loccations and eSIMs (if your device is comaptible can be purchased from inside your Self Serve account. Once you have a new SIM card, you can switch to it in the Self Serve account (Profile section).
09-23-2023 01:38 PM - edited 09-23-2023 01:41 PM
