Need help to complete the transfer from Virgin to Public Mobile
Clarence2
@CS_Agent
I did not respond to the transfer text within 90minutes and now my phone plan is in limbo. I need to receive a new text to complete the transfer of my number to Public Mobile.
Clarence2
ok so i fixed it buy going to my phone settings, cellular, and turning on the e-sim. Thank you all for your answers!
Clarence2
Support told me the account was activated but the SIM he listed is not the same as the one on my phone. When I signed up for Public Mobile I chose the E-SIM option but I do not see a way to activate it.
@Clarence2 the transfer on My Account Profile page won't help in your case
That is to submit a porting request first time.  In your case, the request is already there and hence you will get any error if you try
Please call the porting team number provided by @pmbc . That is the quickest way to get it sorted out
Clarence2
Thank you! I also found a potential fix by going into "Profile -> My Phone number -> Transfer Phone Number" to re initiate the transfer. I will contact the port department if my current method does not work.
pmbc
@Clarence2 You can contact the port dept to reissue the port request.  I'll send you a PM with the number to contact them.
