06-01-2023 08:39 PM
Hello,
I just signed up today and despite the map saying there should be 5G coverage where I am, I only have SOS coverage. This is not going to work, obviously. I foolishly signed up for 3 months, too, based on your coverage map. I cannot make phone calls at home and this is a huge problem. I will need to cancel my plan and get a refund ASAP since your map isn't accurate and I purchased a subscription that you apparently cannot provide. Please let me know what I can do. Thank you.
06-01-2023 08:56 PM
@Laurie_M_5 it usually is a quick fix. Just keep checking the inbox for PM's reply
06-01-2023 08:53 PM
@Laurie_M_5 No worries . I can appreciate your frustration .. your almost there I’m confident support can get you up and running and since you already paid for 90 days worth giving it a try and I think you may be pleasantly surprised with its service once’s you get over this one hurdle …;)
06-01-2023 08:51 PM
Yes, I've done that now, thank you 🙂
06-01-2023 08:50 PM
Thank you! Sorry, I'm stressed out with this situation. I need my phone for work! 🙂
06-01-2023 08:50 PM
@Laurie_M_5 not the chat, but submit ticket via message
06-01-2023 08:48 PM
@Laurie_M_5 we are just customers like you trying to help .. best of luck .
06-01-2023 08:47 PM
Thank you--I did try that already. I went through the steps in the chat, but I still have S0S only coverage, with an occasional one bar popping up, then going back to SOS. I have sent a PM to the agent, thank you.
06-01-2023 08:46 PM
I understand that but Public Mobile also appears to be unable to provide service where I am, despite their map suggesting they do. Thank you for your reply though, I have sent a DM to the agent. (I thought I had done that by posting here, whoops.)
06-01-2023 08:42 PM
@Laurie_M_5 There no refunds with PM it’s pre paid service you should at least use it until your cycle is up if your still not happy , but message support directly and the can help you
06-01-2023 08:40 PM - edited 06-01-2023 08:41 PM
@Laurie_M_5 this could be just a sim card provisioning issue
but try to reboot the phone first, try Reset All Networks
if both not help , please open ticket with support, Private message CS agent at
