3 weeks ago
MY plan is Canada and US. There is no service in the US when i was working yesterday. I change my carrier 2days ago because i needed GPS in the US for work.
3 weeks ago
I have dealt with this problem before. Restart your phone, turn on roaming and set your preference to 4G/LTE as the 5G will not work everywhere especially outside metropolitans. Best of luck.
3 weeks ago - last edited 3 weeks ago
@KIMIAKI If you're using Google Maps for navigation you can download the map area on wifi or cellular data at home to use later when there's no internet connection. It should know where you are but you wouldn't get live traffic info or anything that needs a current live connection. I'm assuming the phone can still detect where you are if you're in the US so that might be worth a try as back-up just in case although the suggestions already given should get data working for you.
3 weeks ago
I will try them as i work tomorrow. Thank you so much for the help.
HI @KIMIAKI
did you try to manually connect to T-Mobile and AT&T ? one of them should work, and you might to test the other one if one does not work (So, don't use Automatic, use Manual connection and pick the one)
and make sure you don't use 5G, better to use 4G or LTE
of course, you need to turn on Roaming Mobile data
3 weeks ago
You're still roaming when you're in the US, but it's included in your plan so there are no extra charges. You'll want to:
1) Turn Data Roaming ON
2) Set Network Selection to AUTOMATIC
3) Set Preferred Network to 4G/LTE (because roaming on AT&T 5G doesn't work)
