12-24-2024 11:24 AM
I have to change service providers from Public Mobile. It was supposed to be done by new service provider but it didn't get ported. I no longer have my PM sim. What do I do?
12-26-2024 03:57 PM
I've started a conversation with someone at customer service. I'm not transferring to another Telus service. We're in a Telus "shadow". That's why I'm transferring.
12-26-2024 03:53 PM
@phil28 You will either need to reinstate your PM account by getting a new sim or esim and subscribing to a plan, or you can try asking customer service for help but they may tell you the same thing. Are you going to another Telus company?
12-26-2024 03:36 PM
I no longer have my pm sim and I have request in to out port my number to a new provider. Can't receive sms. How do I do this now?
12-24-2024 11:29 AM
hi @phil28
this likely cannot be done. You probably have to buy a new sim card, link to your account and then request porting out so you can receive the text to approve
but you can confirm with PM support
submit a ticket with CS Agent using Chatbot here (please select email to receive the 2FA code):
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
12-24-2024 11:28 AM
You have to have PM SIM in order to receive SMS from PM to authorize transfer.
Open a ticket and ask agent if they can help you.
Otherwise you would need to get new PM SIM 😞
12-24-2024 11:28 AM
@phil28, is your PM account still active? If it's not you won't be able to port out the number. If it is still active but you cannot receive the confirmation text you will need to contact a support agent.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
