12-17-2025 11:21 PM
Hi. I currently have a PM eSIM. I would like to change it to a physical SIM card (which I already have from PM). Can I switch the eSIM to a physical sim through the app? Will I lose my number?
Thanks!
12-17-2025 11:47 PM
It worked very easily. Thank you!
12-17-2025 11:31 PM
So I have the physical sim already. At what point do I put the sim into the phone?
12-17-2025 11:24 PM - edited 12-17-2025 11:27 PM
@Carina33 yes, you can change from an eSIM to a physical sim card and keep the same phone number
First, get a Public Mobile sim card from
Once you got the sim card, you can update the sim card number from either the PM app or My Account via the browser
If you are updating via Public Mobile app
login and go to Account page
(If you are unable to login as you don't have a phone to receive the 2FA code: On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email)
click Change your Sim card and update your sim card number there
To update it from My Account via the browser:
login My Account to request Change Sim card
Go to Profile page, click on the Pencil besides the sim card number, follow the steps to enter the new sim card number and complete the change sim card request
(or direct link: https://myaccount.publicmobile.ca/en/account/profile/change-sim-number )
After the sim card is updated, wait 5 mins, then reboot your phone with the sim card and it should be good
