07-07-2026 08:54 PM
I have eSIM came from other provider said yes to transfer , then I have nothing my primary is sos and my secondary is public mobile, which does nothing for me as I have no data , no service and no sms . I’m stuck with nobody to talk to to resolve my problem, this is the second thing today that makes me not want to have public as my provider, but I can t change if I wanted to as I can’t respond to a request to transfer as I have no service I need help now!!!
07-07-2026 09:44 PM
@hairbag1 wrote:
@Ooogie wrote:Ok thanks that worked now I can leave this provider and find on that actually has serve thank you
Ahem; you posted your question...then less than 15 mins later you got a solution that fixed your issue. Less than 15 mins !!!!
I'm confused on your comment @hairbag1 . The solution I gave worked. The customer now has service but isn't happy there is nobody to call (guess they didn't realize PM is self serve), and now that they have service, they want to port out to a service provider that has a number to call and a person to speak with. That is how I read it. How'd you read it?
07-07-2026 09:29 PM
07-07-2026 09:14 PM
07-07-2026 09:09 PM
make sure you removed your old provider sim card (or disable if that is an esim)
Then check if PM sim is enabled. Also make sure its label is changed to Primary. Then Reboot phone and Reset network settings. Test again
if issue persists, ask PM to reprovision the account.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
07-07-2026 09:07 PM
@Ooogie wrote:I have eSIM came from other provider said yes to transfer , then I have nothing my primary is sos and my secondary is public mobile, which does nothing for me as I have no data , no service and no sms . I’m stuck with nobody to talk to to resolve my problem, this is the second thing today that makes me not want to have public as my provider, but I can t change if I wanted to as I can’t respond to a request to transfer as I have no service I need help now!!!
Hello @Ooogie
If your primary eSIM (your other service provider) is now SOS, you can delete that eSIM. Make sure Public Mobile is now set to primary. Then, go into your settings, find Network Settings and clear them. Then reboot your phone and you should be connected to Public Mobile. If that doesn't 100% work, after you've tried that, you can go into Airplane mode for 10 minutes, then turn off phone for 5 and then turn back on, turn off airplane mode and for sure you should be connected.
07-07-2026 09:07 PM
Well I have no service at all after transferring my number a eSIM over I have no service, no text. Primary is sos and secondary is public mobile where do I go from here with no one to talk to to resolve my problem????
