My plan
10-31-2019 01:40 AM - edited 01-05-2022 07:48 AM
10-31-2019 02:32 AM
@darlicious wrote:@cellphoneuser1Apparently if I make a mistake today you're there to clean up my mess. I'm not sure if I leave my tip on the bedside table, in the billfold when I pay or do I discreetly palm it to you when we shake hands?
I'll take a 20
10-31-2019 02:31 AM
@cellphoneuser1 wrote:
@darlicious wrote:@AntkaymommyTThis is a generic error message. Put a 1 in front of the number even if it's local. You can alsobwait for the message to finish and your call will go thru. It s a glitch and usually goes away in a day or two. If it really bothers you message a moderator. Most people wait it out. It will fix itself.
Adding the 1 won't fix that. The message about no long distance add-on or talk not included isn't because of no 1. The 1 only makes it so the long distance calls may apply message gets skipped but without the 1, the call still works. Talk not included or the mesaage about no add-on is a failed call.
10-31-2019 02:23 AM - edited 10-31-2019 02:24 AM
10-31-2019 02:21 AM
@Antkaymommy Dial area code + 580-4001 what happens?
10-31-2019 02:14 AM
@Antkaymommy wrote:Just got a new unlimited Canada wide talk and text plan with data. Now I cant call my voicemail. Says I dont have a long distance add on on my plan
10-31-2019 02:00 AM
You account may not be provisioned correctly.
Try adding $1 to your account to trigger PM server to provision your account again.
10-31-2019 01:51 AM - edited 10-31-2019 01:52 AM
What number is it dialing when you hold 1? Try restarting phone so that the network can reprogram the number.
