My phone was changed without my approval
saif_khusro007
To whom it may concern
My old phone xxxxxxxxxxxxxxxx was ported from my old chart
Few dats later you guys changed my phone number without my approval
The only problem i think was the account with chart with my old no xxxxxxxxxxx was in my wife's name Rukhsana but i was the owner of that account and authorized user
All in all i need my old phone number xxxxxxxxxxxxxxxxx back as i do all my work stuff
I need your help to get my phone number back xxxxxxxxxxxxxxxxxx
Awaiting positive response
Kind regards
Saif
HALIMACS
@saif_khusro007
It sounds to me that when someone requested porting of a number from the other provider, they may have used the incorrect account number,  thus the incorrect number was ported.
It may be difficult to get the old number back and may depend on which major mobile provider the number was originally assigned from.
Yummy
You are talking to customers like yourself, not PM staff.
To contact PM agent:
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
walker1
@saif_khusro007
Your best course of action now is to reach out to a Customer Support Agent and have them look into your account and see what exactly happened to your phone number change.
You'll have to use the Chatbot Simon to get a service ticket started first.
@saif_khusro007 you can try to open ticket with PM support and see if they can asign the number back to you. Possible, just explain the situation
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
@saif_khusro007 @Remove your personal info from this public forum and get Help with a agent right away
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
