Questionable billing
LittleLulu
Jan 1 2023 charged $2.50 on my credit card.  What is this for?
CountyDownIeUk
That’s strange. Keep in mind that a $2.50 charge on your credit card does include taxes. So if you look at your transactions you will need to find a number like $2.23 plus 12% taxes = $2.50.
HALIMACS
@LittleLulu
Sounds like PM charged you the difference between your plan amount and the amount you had in available funds (i.e.  "banked" funds from last cycle)
@LittleLulu   likely a renewal after rewards applied?
Login to My Account using Incognito mode Check Payment history and PM should have shown clearly what was charged and why.  If you have questions., post us the screenshot of those transactions
will13am
@LittleLulu , please login to your self serve account using incognito mode on the browser and check out the most recent payment history and try to match up this $2.50 charge.  It is hard to guess what this is all about.
hairbag1
Could you post a screen shot of you most recent PM billing history ?
@LittleLulu @Did u have credits on your account ? To further investigate contact a agent
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
