My data only works in wifi,. I have LOTS of mobile data but it doesn't work. What to do?
cros1378
My data only works on wifi,. I have LOTS of mobile data but it doesn't work. Several friends are having the same 0riblwm.  What do I do? It's been MONTHS
9 REPLIES 9
popping
@cros1378
Enable data.  Restart you phone and let PM SIM card to configure your APN settings automatically.
If it does not working, you need to manually configure your APN settings.
If you have a LG phone, you need to network reset your LG phone after changing provider before your data working again.
SAM-A
Hey! Did you try re-setting the network settings? I did the same and it worked for me.
Hope it helps!
Thank You!
geopublic
@cros1378  Call 611 from your device and check your data add-on usage how much data do to have remaining? If you have data and you are using Android post a screenshot of your APN settings.
gblackma
@cros1378 enable data and try sending an mms message. If it works your APN settings are correct.  If it doesn't then try @Triguy 's suggestion above.  For more detailed help,  what's the make and model of your phone?  Thanks.  Stay safe.
Lorca
@Triguy lol beat me to it.
Also log into your account and make sure up you haven’t used up your data for the month.
NDesai
@cros1378 Please specify the device you are using. APN is sometimes an issue when data does not work and you have data available to use on your plan.
Lorca
Check APN settings In your phone
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
Triguy
Check your APN settings.
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: Not set
APN protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
Try rebooting your phone.
dabr
@cros1378  You are positive that data is enabled on the phone?
