My account
03-17-2023 02:38 PM
03-17-2023 02:55 PM
hi @Rubesraposo did you activate in store before?
if you activate online yourself, My Account should have already setup.
But you can submit ticket for PM to check and set up one for you
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
03-17-2023 02:51 PM
@Rubesraposo Activating a SIM card is what sets your account up using the same email and password you used to activate SIM card … unless you activated in store awhile back and never created a my account then you would need support to help you create a my account
- Get support by starting a conversation with virtual Chat box /SIMon. Click here
- you can send a private message To CS_Agents by clicking here.
Watch for reply top of page to the
Right ( envelope image )
03-17-2023 02:40 PM - edited 03-17-2023 02:42 PM
top of this page click Activate for guidance.
amended...
https://www.publicmobile.ca/en/bc/get-help/articles/create-a-self-serve-account
03-17-2023 02:39 PM
@Rubesraposo If you're talking about activating a SIM, go to this link.
Activate Your SIM Card Online | Public Mobile
You'll need.a SIM to begin with and follow the wizard. Through this process you can select a new number of choose to port an existing number.
