01-07-2023 02:35 PM - edited 01-07-2023 04:10 PM
01-07-2023 05:32 PM
oh, I thought it was just me. Glad it wasn't me only and it works now. 🙂
01-07-2023 05:07 PM
I think that's what happened, @Luddite @softech @dabr @dust2dust
I got a red box, warning message about "post flooding" with respect to that particular thread when i attempted to post a reply?
01-07-2023 05:04 PM
properly we all replied too quick and overheat the system.. lol
01-07-2023 04:59 PM
@HALIMACS @dust2dust yes; noticed it too and messaged the CSAs. Next time just send them a message.
Twas quite weird as only the English forum was affected. Can only assume someone was tweaking a piece of the system and screwed up.
01-07-2023 04:49 PM
I also tried to respond to OP's post over an hour ago and was unable to post my response to this and another thread. Seems like there was a serious glitch.
I did alert CSA's and also private messaged one of the senior CSA who I noticed was online and he was unable to edit OP's post either. He did private message OP and I'm relieved to see @schinz13 edited his post, however, @schinz13 I think you should also change all your logins/passwords and maybe even your email adress to be on the safe side.
01-07-2023 04:40 PM
PLEASE remove ALL your personal data from Public forum. We are all customers here and you are not communicating with PM staff.
Contact agent to do that for you.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
01-07-2023 04:34 PM
Indeed... I used the report feature as well as no updates could be made to the thread.
What is concerning for this OP is that their post sat there for almost 2 hours before it could be edited.
01-07-2023 04:32 PM
@schinz13 @Please remove your personal info under your name to the right next to time stamp tap arrow and edit , this is a public forum
edit this was time stamped 3:05pm
01-07-2023 04:29 PM
@HALIMACS- I had the same mystery. I reported the post. But I see the OP edited it. So all good.
01-07-2023 04:23 PM
Please edit post.
This is a Public website - use downward arrow on your post to edit.
(i originally posted the above message about 2 hours ago - PM Community must've been messed up there for awhile... 🤔 )
01-07-2023 04:11 PM
to reset password, please open ticket with PM support
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
01-07-2023 04:05 PM
